Home dbx User Forum dbx Archive Threads DriverRack PA & DriveRack PA+ PA Connectivity
DriveRack PA+ with QSC KW Series
PoppafryPoppafry Posts: 3
edited November 2016 in PA Connectivity
I am running the DriveRack PA+ with 2 - QSC KW153 3-Way loudspeaker system and 1 - QSC KW 181 Subwoofer.
I am having trouble getting the sub to work.
Could someone help me with the proper connectivity and set up in DriveRack?
  • DraDra Posts: 3,777
    Assuming that the QSC's are not in the wizard, select Passive -Custom tops and Mono subs - Custom.
    Connect the tops to the high outs, and the sub to left (mono) low out.
  • Thank you!!!
