Basic set up help ASF224 DUAL CHANNEL FEEDBACK CONTROLER
Hi,
Complete Newbie.
Just checking if I have the wiring connection correct.
The schematics in the manual seem vague.
Basic PA system.Power Amp, Mixer unit, and Passive speakers.Single microphone used.
I used a TRS SPLIT Y LEAD, ie TRS x 2 mono jack ends.
I connected the IN /OUT on the ASF224 with mono jacks and the TRS into the microphone channel ,channel splitter at the back of the mixer.
ie passing the microphone signal in and out of channel one of the feedback controller.
It seems to work.
Is there a better way?
Any help welcome
Regards
Colin
Complete Newbie.
It seems to work.
Any help welcome
Regards
Colin
The good news is that if you incorrectly plug in the two plugs into the 224, that no signal will pass. If you say that it seems to be working, and pulling out feedback, then it is working.
Im still getting feedback.Is there any better diagrams as to connections other than the vague ones on instructions?
IM NOT TRYING TO DO ANYTHING COMPLICATED OTHER THAN KILL FEEDBACK ON ONE MICE.
ANY HELP WOULD BE APPRECIATED. Did not mean to shout.
Cheers
Colin
Is it maybe in bypass mode? Do you have the manual? If not it is available online.
Hopefully you won't take another month to reply. It is hard to accomplish much that way.
