Use only EQ in DRPX
Hi,
I use Mackie's SRM450 with SWA1501 subs and the internal crossover (@120 Hz) built in the subs.
How can I bypass the crossover in the DRPX to send the fullrange signal to my speakers?
Is it enough to use e.g. the SRM450 setting, or will I loose the low frequencies?
The SWA1501 Manual says 36HZ, -10dB and 47Hz, -3dB.
Finally I want to use only the EQ-section to correct frequencies causing bad responces in the room.
Thanks in advance,
Joe
Thanks in advance,
Joe
