Venu360 setting up for karaoke
Hello all,
I have a Venu 360 , I want to setting it up for my karaoke system, but I don't know anything about the x-over, compressor , and limiter, I'm try to follow thru the set up manual and the wizard. Music came out okie, but my problem is the vocal come out not really smooth, I feel something compress on the sound , it really heavy and really tired after you sing a song, anyone can help I really want to learn. Thank you for your help
Here what I have and my connection
Mixer onyx 1202 - bbe 882 maxizer- venu360
Speaker I used Qsc K12 for my main
And 2 custom passive speaker for karaoke
Amp for that 2 speaker is crown crown 2000
Sub 10 Krk
Sub 10 Krk
Thank you for your opinion, but I have some more question to asking
1) I had read the topic about set up the ccross over for PA+ can I apply that to venu360 ?
2) Please give me some opinion on this set up for cross over.
High
Hpf 102 bw 18
Lpf out bw 18
Gain -0.8
Phase -25
Low
Hpf @240 bw18
Lpf @ 20khz bw18
Gain -3 db
Phase 0 because I don't know
Sub
Hp frequency @ 45 hz bw 18
Lp freq @ 98.4 lr 24
Gain 0 ?
Phase -105 deg , I have this number when I run speaker config on wizard
For my compressor
Threshold: -4.3 db
Gain: -1.7
Ratio 4:1
Over easy 10
This set up I copied from someone in google
Like you said I don't need to turn on compressor and limiter so I turn it off.
Again I'm really appreciate your help
I didn't notice the sub before, but is can't keep up with the K12's. I you feel that you want to use it, I would suggest setting the K12's as HIGHS: 70 hz LR24
Set the sub and LOWS: 45hz BW18 - 70hz LR24
Not sure how you are using the "customs".
Those phase setting? Wow! Unless you are using the exact same speakers, set-up in exaction the same positions, and in exactly the same room.... they are useless. In other words, It is beyond you, and to have to have special software to set those.
Try comparing the K12's by themselves - 55hz BW18
