QSC k12.2 update support in PA2?
Will there be a new firmware update that supports the new QSC K2 series? In particular the K12.2 and K10.2 ?
Also, when using the K or K2 series, should the tops be left in EXT SUB when running with subs through the PA2?
You will have to contact DBX for you first question.
When connecting speakers through the PA2, you should set them to accept a full range signal (no filters applied).
