DriveRack PA2 and SRX828SP setup questions
Greetings all!
Has anyone had any experience setting up a DriveRack PA2 with the JBL SRX 828SP powered subs?
I own the 828SP subs and there are no speaker tunings for this model. Does anyone know the proper "setup" needed for using these subs with the PA2?
I read one post for the SRX 828 SP but using a different DriveRack model. Does this configuration work with the PA2?
"The EQ processing is already taken care of inside the speakers. You just need to set up a x-over point. 100hz LR24 should work just fine."
I would appreciate any advice you can give me setting up the PA2 with the SRX 828SP subs. I am a newbie and would appreciate any help.
Thanks for your time!
Andrew
Andrew
