Problems with the 360 fan
Will this be solved with some software update? or you have to adapt another fan to the equipment, it will not be a good reputation for the brand when these videos are uploaded where these adjustments are made since the equipment gets too hot.
1
There is not any issues with the fans. There was an issue with the Power Harness that needs to be resoldered for sound cutting out. This has been long since resolved at a manufacturing level. There is a tech bulletin available to resolve the issue, two points to be resoldered.
Make sure you contact tech support for these service options if you need assistance.
844-776-9569 opt 3
hprotechsupportUSA@harman.com
