Home dbx User Forum dbx General Discussion
pa2 user presets
I'm having a situation with a new Drive rack pa2. If I pull up a preset and modify it then hit the store button it's stores the preset. However if I power down the unit or choose a different preset when I go back to the preset that I had modified and stored the store light is lit again even though I haven't done anything. This happens to any preset that I have modified and then stored every time I choose one of those presets the store light is on. I've called tech support and they are kind of compounded over this anybody else experiencing this thanks
  • By the way I have done a soft reset and I've also done a hard reset. When I did the hard reset all of the user presets they came from the factory all came back as they were and I have and I have no issue with the store light being lit if I choose any of the presets so it doesn't look like it's the memory that's funky anyways
  • EEldeEElde Posts: 1,376
    What firmware version are you on? Try to go to version 1.2.0.0 if you haven't and verify that this issue is not persisting? I have not heard or seen this personally no. It might be an issue with your firmware though is what I am thinking. Reflashing might help with the Factory Manufacturer's Updater. We have options to try further. Email or contact tech support
    844-776-9569 opt 3
    hprotechsupportUSA@harman.com
  • when i hit store it shows the list of stored and i select the one i want to overwrite and hit store again. you have to hit store twice, but make sure you keep track of what number you were on and rename it.
