My Go Rack no longer works
Hello,
My Go Rack no longer turns on.
I took it apart but I can't find an internal fuse.
Can you help me.
Thank you in advance
Jean BERNARD
Or maybe a reset.
How to do ?
There is no internal fuse. make sure you have the PS0913DC adapter to power the GoRack
Reset procedure:
Remove Power First
Press and Hold both SUBSYNTH and EQ button and apply power to goRack. Release buttons after 8.8. is displayed. (Note: all the 5 buttons should now be lit red as well.) Press and Hold the MUTE button for about 2-3 seconds, PS should be displayed that stands for PASS – which is an internal memory test. Doing this memory test also performs a Factory Reset. Now power cycle and the product should be back to default.
I tried your procedure.
No LED lights up.
Unfortunately it sounds like it is something wrong either the adapter or the goRack itself then. Please contact Tech Support to see about service options (info in signature)
