Home dbx User Forum dbx Live & Portable Products
360 VENU DBXVENU360-V Speaker Set up
Hello,
I recently purchased the Driverack Venu 360 and am seeking help with my speaker set up. Eventually, I will go to a set up with two mains, two mids, and two subs. Currently, I am operating two mains and two subs.
I am using two DFX Pro Audio 215 3-way Full Range mains.
500 Watts RMS
Frequency Response of 24Hz-20Khz
Power Handling: 1500 Watts
For my low end:
I am using two Cerwin Vega CVi 218s
Frequency Response: +/- 3 dB 51 Hz-200 kHz
Operating Range: -10 dB 36 Hz
Nominal Impedance (Ohms): Full Range 4 Ohms
Axial Sensitivity (dB SPL, 1W / 1M): Full Range 100.5 dB
Calculated Maximum Output (dB SPL, @ 1M): Full Range 134 dB
Power Handling (Watts): RMS 600 W / Program 1200 W / Peak 2400 Watts
How do I configure my speakers?
  • Phaze3Phaze3 Posts: 2
    I figured it out
  • EEldeEElde Posts: 1,376
    Sorry for the late reply. Definitely what you want to use is the Frequency Response for your crossover setup. If you have further questions please let me know?
