Driverack PA2 Mono Mid Outputs
Is it possible to set the Mid right, left or both outputs to mono ?. This means that each output reproduces the sum of the 2 stereo input signals, as happens with the Low output right?
1
Nope, only the Low Outputs have the ability to sum mono for a Mono Sub etc. The PA2 has only stereo crossover applications, with a mono summed sub option etc.
Thanks !, with the Venu360 if it would be possible?
You're welcome!
Yes the Venu360 is more modular and every output can be carved out with 1x1 Mono Crossovers
Perfect, thanks!
