Home dbx User Forum dbx General Discussion
Desired Crossover setting is not in presets Venue 360
sawadee33sawadee33 Posts: 1
edited July 2021 in dbx General Discussion
Hello experts, I want to do stereo 2 way + mono kick sub + mono sub crossover setting. But I cannot find presets in venue 360. Is there anyway to do that?
  • EEldeEElde Posts: 1,376
    You can actually go into Configure mode and change the routing of your inputs into whatever outputs and adjust each output to have it's own crossover type (so if you need 1x1 crossover outs with both inputs routed to it summed for example). This comes in handy if there is not a Factory or Custom Preset that matches what you want to do. You can adjust the crossovers to let out whatever frequencies you want. Then use the Store functionality to save your settings
