I found the solution myself!
The problem is the framework software
You need to install manually the framework 3.5 manually and after that you can Install the ZonePro Gui Designer on windows 11
Yep indeed, this article helps with the issue:
https://help.harmanpro.com/Pages/ZonePro Designer Windows 10 & 11 Microsoft -net Framework Issue.aspx
