Home dbx User Forum dbx Software
DriveRack PA2 - Keep the graphic EQ engaged while running AutoEq
I have flattened out my Yorkville Elite system outdoors in free air with the graphic EQ and an external RTA. Now I would like to use the Auto-EQ function to make fine adjustments in venues, but use the graphic curve as the starting point. To do this, I'd need to leave the graphic engaged while the Auto-EQ runs. Seems the graphic is disengaged by the software when the Auto-EQ Wizard is run.
Is it possible to over-ride the software toggling the graphic off during Auto-EQ?
  • EEldeEElde Posts: 1,376
    The graphic EQ will not be engaged while the AutoEQ is running no, since the Auto EQ module runs post crossover.
