Home dbx User Forum dbx Software
ZonePro Designer Scene File?
Short of burning through a LOT of pencil lead, paper and LABOR, is there any way to save the SCENES/SCENE SETTINGS of a ZonePRO .zpd file to load into another .zpd file? The problem (I believe a design flaw) is that when editing an existing .zpd file's configuration (like adding/editing a Zone Control) , the software clears all scenes from the file. As far as I can tell, all those settings are GONE. That's a lot of work to lose/re-create EVERY TIME a client wants a change in the configuration! is there some work-around for this?
  • EEldeEElde Posts: 1,376
    If you have Scenes and then go through the Configuration Wizard it will clear the scenes, there is no workaround for that. You cannot save scenes individually no so if you make a backup .zpd file it will have the scenes but if you make any changes to the file and then reload that file the changes you made will not retain.
    The Default scene will not be affected though, just the additional scenes.
