Home dbx User Forum dbx General Discussion
Venu360 fan not spinning
I’ve noticed that the fan on my venu 360 is not spinning?
Is that normal?
  • EEldeEElde Posts: 1,376
    Yes, the fan will only come on when there is enough of an heating issue where it needs to. It is not on all the time by default. It actually takes a lot of heat for the fan to come on.
  • Thank you
    @aaronnkosi said:
    Thank you
    No problem! You're welcome!
  • szenherszenher Posts: 1
    Where is the fan temperature sensor located on the circuit board?
    I want to make sure it will turn on if I use a heat gun to activate it because I suspect it is not turning on at all and caused the power supply capacitors to fail.
