Home dbx User Forum dbx General Discussion
DBX DRIVERACK PA2 FOOTBALL FIELD SET-UP. Needing advice.
Needing help to run DBX Driverack PA2 on an outdoorfootball field. Using 4 JBL AWC129's ( 1 stacked on the other "line array" on each corner of the press box. The top speaker is set for high and the bottom is set to midrange. Also added 2-JBL AWC 82 in the middle also set to high frequency. Running 3 Crown XLI 1500i amplifiers and 2- JBL 18" POWERED subs. Running through a Yamaha mixer. I can set the auto EQ With the RTA mic but once completed, the finished sound is terrible. Where have I gone wrong? Any advice on how to get this audio system sounding spectacular? The equipment is there, the quality unfortunately is not. Any and all suggestions/advice greatly appreciated!
  • EEldeEElde Posts: 1,376
    How far is the RTA Mic from the speakers? Also - what target are you going for?
