Using driverack pa2 with 3 active full range Yamaha pa speakers
I don’t have lows, mid or highs I only have my 3 Yamaha pa speakers with full range. When I connect them I set up them on the Highs and set full frequency range. However the lows get set up by default so I cannot run the eq check with the flat dbx mic… as it gives error because there are no lows connected so they don’t give a feedback signal to the mic. How do I remove the lows from the full setup?
