No output from one input channel
Hi I have been using the DriveRack PA for some time with no problems and at the last gig I had a problem and now after testing back in workshop after gig, I can see that one input although showing on the input meter and the two output meters (H & L) is not delivering anything. I am using an Allen & Heath desk and have confirmed both L&R are outputting a signal and have swapped input cables from the desk to the DriveRack and proved that it can process either from the desk, but only passes one through. Any thoughts would be welcome
Please ignore, we were being a bit dense with our own setup. Problem solved.
