Home dbx User Forum dbx General Discussion
Driverack 260 Rapid Power Cycling or Boot Looping Problem
Have a Driverack 260 that will not start up properly. Randomly failed when system was not in use, power on. Audio signal not being output from unit.
When power is applied, both the display flashes and internal relay clicks around 2-6 times/second. No change in symptom using power switch on rear of unit.
Would soft or hard reset help?
Any help greatly appreciated!
