presets on the pa 2
I tried using the preset 4frwstsub. it only lit up the high and low channels. wanted to have 4 main and 2 sub outputs. i had to make my own so i started with 6fr. set the low to cut off at 135 hz. set mid and high to run from 100hz to 20,000khz. Even when i used active crossovers i lapped over a little so i did not loose a frequency, thus 100hz/135hz. just not sure why there was no preset built into the unit for 4 mains and 2 subs. I named my new settings 4-2Way-W-St Subs. Seems to work how i want it to now.
