Multiple DriverRack PA2 issues when run together
I had two PA2 on the system and I was able to search / see and connect to them in the management application. I then pourcahsed two more and now the problems becomne evident. The application will never display more than two devices and the two it displays is very random. The only way to manage specific devcies is to pull the LAN cable from 2/3 other devices. This is impossible when the devceis are at the stage and the management app is at the FOH mixer. Had I know that I would find such basic bugs, I woudl never have bought these as it concerns me now what other not so obvious bugs I am yet to find. I have already seen devices needing rebooting after some rest recalls to be able to subsequently manage them again and also unless the dhcp server is running, 50 % of the time you have to reboot again to get an ip address meaning the power up order is critical whuich is impossible at big venues. I am running 1.2.0.1 on the PA2's and the app is 1.1.4 Has anyone esle seen these problems, I accept 4 in the same system may not be common. I have only pourcahsed the PA2's in the last gew weeks and am already starting to get very dissapointed, I hope there is a simple resolution out there that could restore my confidence.
