Home dbx User Forum dbx General Discussion
Driverack pa2 use for 4 way crossover
If I have two dbx units, can I combine their uses to setup a 4 way crossover? If so do I daisy chain the outputs like on the first dbx units have tweeter, then mid range and woofer output going into the second dbx units. Then use the second dbx unit to crossover the woofer and subwoofer? Or should I split the main inputs with a splitter and feed that to the two dbx units? Or another way? Thanks in advance for your guidance.
