RP360 and effects loop
Hi All
Recently bought an RP360, should it work with output into return on a Boss Katana?
Answers
  • You can run a send/return to the in and out of the RP360 yes.
  • Hi
    Thanks for reply.
    Do you mean send to in and return to out or other way round?
    Will it work into return only?
  • HARMAN_EEldeHARMAN_EElde Posts: 84
    edited January 27
    @a1terrier said:
    Hi
    Thanks for reply.
    You're welcome! No. It needs to have an signal sent through the unit for it to effect the signal, it will not just send effects via a return because it has no signal flow to pass on the effect.
  • Ok thanks
