Home DigiTech Software
Nexus
Hello, I have a question about Nexus software. I own the RP360 multi-effect. When I delete or add effects with Nexus, it doesn't change anything in the pedal! Is this normal. Do you have a manual for Nexus?
Sincerely
Gérard
  • After you have made a change you need to store this either by using the Store button on the RP360 or in the software under Quickstore or Store New
  • WERE CAN I GET NEXUS SOFWARE PLEASE
  • BazBaz Posts: 4
    Hello All... since I've updated my Mac to CATALINA the Nexus software font shows as squares, and not actual letters. I can't find a way to change the font to where I can read the different settings. Any ideas? Any and all help is greatly appreciated... Thanks...
    We've put in an notice to our engineers to fix, hopefully soon but I have no exact ETA/Schedule as of this time. We're hoping ASAP.
  • Spider5Spider5 Posts: 1
    Installed Nexus 1.0.2 on Windows 10 pro 64 bit. It refuses to see the RP150 pedal. Have installed X-Edit 2.7 no problem, it sees the pedal OK but seems crude and long-winded to use. Is there an update somewhere for Nexus1.0.2 ?
    Spider, the RP150 does not use Nexus, only the RP360/RP360XP does. X-Edit is what you need to use for the RP150.
  • sawalgetsawalget Posts: 1
    Hi! After update Mac OS to Catalina, fonts in Nexus Driver looks like squares :(
    It's a very sad because it make a device unusable. Please help to fix that problem.
    Yes it is a known issue, they are going to have a fix soon for this issue. No schedule or ETA but very soon.
  • fernanharofernanharo Posts: 1
    I have a problem with my RP360, I try to record with the usb input on my computer with the DAW cuebase 10.5 and it does not transmit any sound, do you have any new drivers for windows 10? or is the problem another?
  • HARMAN_EEldeHARMAN_EElde Posts: 875
    The RP360 is tested and working with Windows 10 latest build 1909 and I have tested it with CuBase 10.5
    Make sure in Cubase you have the correct device setup and is active for use in the Studio Setup. If you are still experiencing issues please contact tech support in my signature below.
    Has this been resolved? I have the same problem
    As of now no resolution but there is still an existing escalation to our dev team to fix but no schedule or ETA for this as of now
  • I see the problem with the square letters in Nexus for the RP360 XP hasn't been resolved.. I really liked my foot pedal but its time to get a Line 6 Helix since nobody gives a shit about this product at Digitech to solve the issue after thousands of people paid good money to support your company!
    edited August 2020
    Unfortunately yes the issue is not resolved. It's not for lake of caring, at least from a tech support perspective as we have reiterated many times that it needs to be updated. We are still putting pressure on them to resolve these issues. I am told this issue will be resolved but I just don't have any ETA/schedule for that.
    I do have a Line6 HX Stomp myself, (and a Fractal FM3) much more expensive units but they are great. I wouldn't blame you moving onto that as well if you can't use an earlier OS of Mac to use Nexus.
  • so has this square letter issue been resolved yet?
  • Looking back, the square letter thing has been going on since March - I can't help but think you aren't serious about sorting this out, otherwise it would surely be done by now. If you don't intend fixing it, please let me/us know so we can get something better supported by another manufacturer. Thanks
  • I've been told that updating to Big Sur resolves the issue. Another customer was also able to resolve it by hooking up to a Windows 10 Machine, and when he came back to his 10.15 Mac, the character issue was resolved.
    As I stated in another thread, the RP360 being discontinued, they have decided to end developmental support for the Nexus Librarian software. You can try the above suggestions is all we have as far as a solution/
