Home DigiTech Forum DigiTech Products
RP55 Issue (Not Working)
Hello,
I have a Digitech RP55 for about 8 years. No problems at all on that period of time. But a few days ago when I plug it to the power brick it starts but then “Pd” appears on the screen and I can’t do nothing. I already Factory reset it twice. Nothing. No audio no nothing. The power brick is working fine since I already tested it with another Digitech pedal. Below you can find URLs for both pictures.
Any suggestions?
Thank you in advance, I look forward for your response.
Rod Requena.
https://ibb.co/98mXwgt
https://ibb.co/wQsJNZ4
  • HARMAN_EEldeHARMAN_EElde Posts: 1,166
    @Tonkpills said:
    Hello,
    Any suggestions?
    Rod Requena.
    We've run into that issue, and unfortunately it's something that we do not have a fix for if the factory reset is not successful in resolving. The RP55 in the US is only covered for Warranty Replacement for 1 year, after that the cost of fixing it would be the same price as procuring a new unit.
  • I have the same problem with pd issue on Digitech RP 55 you have any solution ? Thanks
