Home DigiTech Software
X -EDIT FOR WINDOWS
WERE CAN GET A WINDOWS VERSION OF X-EDIT
  • Mr_ScaryMr_Scary Posts: 39
    Does this version work with GNX3000 / GNX4 ?
  • HARMAN_EEldeHARMAN_EElde Posts: 610
    Should be fine yes
    Thanks I'll give it a try.
    I get the same error in X-Edit 2.4.1, and 2.7.1
    Loading Presets... and never goes beyond that.
    Okay it works with the following settings in my situation.
    X-Edit 2.7.1, and 2.4.1 both
    Windows 10 1909 (18363.836)
    under compatibility settings for Windows XP (Service Pack 3) Only.
    Will not work under windows 7 compatibility.
    Good to know, thanks for the follow up. I have done with the latest Windows 10 build on the RP500 and RP1000 and did not need to change compatibility settings, perhaps that the GNX stuff uses a different and older driver is probably why
    I should have mentioned in my post that I was using a GNX3000
    After getting it working with WIn XP Compatibility,
    I have changed compatibility to Windows 7 and its working. So it does work.
    • Windows 10 1909 (Compatibility for Window Windows 7)
    • X-Edit 2.7.1
    • GNX3000
    • X-Edit 2.7.1
    • GNX3000
    Cool, thanks for the additional info!
