Home DigiTech Products
TRIO+ with stereo mix & guitar FX solution
bether69bether69 Posts: 5
edited March 10 in DigiTech Products
Hi,
Unfortunately TRIO+ can play only mono guitar FX by "FX return" but we can use eg. Zoom G1on mutlieffect to jamimg with stereo guitar fx (stereo delay is pretty cool).
Sorry but in this way we can't record loops because "FX return" is muted. Unmuting it allows to record a clean guitar signal and bleeding to headphones mix.
Look at my connections:
  • HARMAN_EEldeHARMAN_EElde Posts: 356
    The FX Loop in the Trio+ does not have stereo out or in unfortunately no.
  • bether69bether69 Posts: 5
    edited March 25
    Yes I know that. So, but if we use slightly smart connections then will be great stereo output guitar FX and drums when play with Digitech Trio+ and Zoom G1on :-)
    Needed the mixer (I have Yamaha AG03), Zoom G1on and stereo switch box Delock 2 port stereo switch and few cables.
    If I want to record a loop (mono) in Trio+ then I switch to 2 (stereo switch box).
    But if I want to jam using my favourite stereo delay then I switch to 1.
    The both switches allows to learn Trio+ :-)
    Look at my photo.
    Understood thanks for the explanation and photos, that's pretty cool, but there is not a fix or a workaround for this unfortunately is my point right now, but I can definitely pass it along as suggestion for a product update to make this easier to utilize in the future with less equipment. Cool setup!
