Home DigiTech Forum DigiTech Software
On my Trio-v-02 the learn flashes
I play a chord sequence then hit the footswitch to play but it doesn't. What's wrong?
Answers
  • HARMAN_EEldeHARMAN_EElde Posts: 1,100
    The LED above the band footswitch will flash red slowly, this means it is ready to be armed. Press once and it will flash more rapidly, this means that you can start playing and the LED will go solid while it is learning, pressing the Band footswitch at the end of your chord sequence will then play back the band track automatically.
    If the LED never goes solid Red, then you need to either make sure you volume knob on your guitar (not amplifier) is turned all the way up, and that you do not have any pedals in between the Trio+ and the Guitar.
