Home DigiTech Forum DigiTech Products
Whammy 5 Pedal - No Wet Signal
Hello,
I have a Whammy (version 5) pedal that is out of warranty. The pedal has recently stopped working. Here are the symptoms:
Pedal powers on (using the harman pro group ps200r 120)
Dry signal works fine
There is no output sound when effect is engaged
What I've tried so far:
Calibration - I have re-calibrated the pedal multiple times.
When calibration mode is engaged - All LED's blink.
I have tried many different audio cables both input and output.
I have removed all other pedals from my signal chain.
My current setup is guitar>whammy>amp
Please help. :neutral:
  • HARMAN_EEldeHARMAN_EElde Posts: 1,105
    @brefmint said:
    Hello,
    Pretty much service will be your best bet at this point (out of warranty service is available, in the US there will be a fee from out factory service center) and there are no repair or fix tips other than what you have tried. Contact for tech support is in my signature if you are in the US and need to setup service. Outside of the US you can contact for Europe - [email protected] and in Asia/Pacific - [email protected]
