Home DigiTech Forum DigiTech Products
Jamman stereo backwards compatibility with solo XT
Hello I use a jam man stereo currently and want to have a backup like the solo XT in the case that the stereo fails during a gig. Does anyone know if you can take the the SD card out of a stereo and put it into a solo XT and have it work?. I have confirmed that this does not work with the older solo model.
  • HARMAN_EEldeHARMAN_EElde Posts: 1,100
    They are formatted differently so no, simply swapping the card will not work. The only way you can do this would be with the JamManager Software or by manually copying the JamMan Stereo directory and making it the same for the Solo XT, which would require a lot of work.
  • dgionisdgionis Posts: 3
    Thank you @HARMAN_EElde !!!
    You're welcome :)
