Home JBL Professional User Forum JBL Pro Live Portable Products
JBL PRX ONE
I can’t seem to get anything out this unit. It says I am connected via Bluetooth but it does not seem to function. I have tried playing Spotify, hooked up a microphone and an acoustic guitar through a DI box and I get no sound at all. I tried using the app and I tried using the controls on the actual mixer. No luck. I have used units similar to this for a while now and never had any problems like this. Anyone have any ideas?
  • Make sure App is working on Bluetooth. All channels are shipped at -100 or mute from factory. A lot of people have this issue. Call JBL tech support, they are helpful.
  • You have to turn up the volumes way higher than is logical. I’m not sure why they wasted half the volume control on silence, but that seems to be the case.
  • Sorry to hear you're having trouble with your JBL PRX ONE. It sounds like it could be a few things to check. First, ensure that the Bluetooth connection is properly paired and the volume levels on both the unit and your device are set correctly. Sometimes, Bluetooth can connect but not fully sync for audio output—try disconnecting and reconnecting the Bluetooth to see if that helps.
    For the microphone and guitar, make sure the input channels are correctly selected and the gain is turned up. If you’re using a DI box, check the DI settings and the cable connections as well. Additionally, try testing the unit without Bluetooth by plugging in directly with a cable to see if that resolves the issue. If none of this works, consider doing a factory reset or contacting JBL support for further troubleshooting.
  • El JBL PRX ONE es una adición impresionante al mundo de los sistemas PA portátiles. La integración de la renombrada tecnología de audio de JBL con las características avanzadas del PRX ONE lo convierte en una solución ideal tanto para eventos pequeños como grandes. Desde su claridad en el sonido hasta la versatilidad que ofrece, el PRX ONE parece satisfacer las necesidades de los profesionales de audio y los artistas que requieren tanto potencia como portabilidad.
    El hecho de que venga con una mesa de mezclas de 8 canales y procesamiento de efectos incorporado es un cambio de juego. Tener todo lo que necesitas en un solo sistema facilita mucho la configuración, especialmente cuando trabajas en lugares con espacio o tiempo limitado,. Además, la supresión de retroalimentación y la ecualización automática del sistema son herramientas excelentes para optimizar el sonido en tiempo real sin necesidad de mucha intervención técnica.
    También me encanta que esté diseñado para ser rápido y fácil de mover. La construcción robusta y liviana garantiza que se pueda transportar sin mucho problema. Esta es una gran ventaja para DJs, organizadores de eventos y artistas móviles que necesitan un sistema confiable para una variedad de lugares.
    Un aspecto que me gustaría saber más es cómo se desempeña en lugares más grandes. Aunque parece estar diseñado para ser lo suficientemente potente para espacios más grandes, sería bueno escuchar más sobre sus capacidades en escenarios de eventos grandes. En general, el JBL PRX ONE parece una solución excelente tanto para la calidad de sonido como para la practicidad. ¡Tengo muchas ganas de ver cómo se desempeña en acción!
  • qasimqasim Posts: 1
    Hello guys, I've been using this site for the last 5 years and found it one of the best sites for online earning.. deposit easily with the help of this website click here and start earning today.
  • lillysss22lillysss22 Posts: 3
    edited August 26
    It sounds frustrating when everything shows as connected but no sound comes through. A few things you might try: double-check that the correct input channel and gain are set, make sure Bluetooth is selected as the active source, and confirm the master volume isn’t muted. Also, test with headphones directly from the unit to see if signal is passing through at all. Sometimes it’s just one overlooked setting, kind of like missing a small detail in a Malbild that throws off the whole picture. If none of that works, it could point to a firmware issue or even a faulty unit.
