Arrayability of VTX F Series?
I am looking to learn if the JBL VTX F35 or any of the F Series speakers are designed to be arrayed. Any help is appreciated.
Hi,
The VTX F35 is available in 2 coverage patterns the /64 (60° x 40°) and /95 (90° x 50°). Typically, you would use the /64 in an array if wider dispersion with Higher SPL is required. As long as you follow basic rules for arraying speaker horizontally (not over lapping too much) you should be fine.
