PRX735 - No sound
I have a PRX735 with no sound output. The back panel appears in order with the green signal LED flickering with a signal. The Blue LED on the front is on but there is no sound. Any suggestions please. Thanks
1
Answers
Hi rayc.
several options are possible. Perhaps the speakers are broken.
or the cable has moved away from the inside of the amplifier to the speakers.
In any case, I advise you to take to a good service center
hi ray
damage is on the input usually ic 33078
I can't explain exactly. because it can be different.
you can also ask for help at your local service center.
hope it helps
