Problem updating EON718S to latest firmware
grostire
Hi,
I'm trying to update my current firmware 5.0.4.0 to the newest 5.0.6.0. However, in the JBL Pro Connect android app, when I tap update, after a couple of seconds it says "Firmware update failed. Reboot speaker and Retry". At that point, back LEDs and front LED are all yellow, and I need to unplug/plug the subwoofer from AC power to revive it.
Does any of you had this issue ?
I'm trying to update it, because I heard there was some issue with the limiter, which I encountered. I'm hoping it will fix this issue. However, I cannot find any firmware Release Note.
Thanks !
When it says, "Reboot," it may mean you should Factory Reset the unit before attempting the Firmware Update again-
https://help.harmanpro.com/factory-reset-procedure-for-the-eon700-series-speakers
That should help that. After that, just be sure you're also using the latest version of the Pro Connect app, and you've closed out of and reopened that, as well.
That's what I would try
It worked. Thank you very much !
