Home JBL Professional User Forum JBL Pro General Discussion
JBL Partybox 110 damaged woofer replacement help
Hello guys, i need your help.
I have a JBL PartyBox 110 with a damaged woofer due to a fall. Unfortunately, I can't find an original replacement woofer for it but, i did find a used PartyBox 100 that's being sold for parts. The question is, can I replace the faulty woofer with one from the PartyBox 100? The dimensions seem to match, but I'm concerned about potential sound quality differences. Would the 100's woofer be weaker or significantly different in performance?
Alternatively, can I replace the damaged woofer with an aftermarket one that has the same dimensions and power rating as the original? I've heard about drivers and other technical aspects, but I'm not familiar with them. Could you explain if this is a viable option and why or why not?
Thank you in advance for your help,
