Home JBL Professional User Forum JBL Pro Live Portable Products
Okay, new PRX ONE (TWO) idea.
Alright, take a PRX912 or PRX915, outfitted with a stick socket with the bottom stick of four 4" drivers and top stick of six 2.5" drivers. Give it full cable less bluetooth capabilities and the ability to be controlled by one of the Soundcraft Ui mixers. The stick configuration was just a wish based on nothing but an idea. This would allow it to be run in true discreet stereo if desired. Because the 12's and 15's are lighter it may be necessary to add weight of brace (stand) for stability. Other than that it would be a winner to me.
Seeing as EV is coming out with their 70 series stick (others will follow) this would be a great one ups for JBL with pretty much all off the shelf components. BTW, I would buy two right away.
What do you think?
  • BTW, instead of the PRX912 or 915 you could just use a PRX915XLF or 918XLF and no need for a brace or additional weighting for stability. Total bluetooth wireless for mains, subs and monitors is the trick.
  • Also, no need for PRO CONNECT
