Does the AXB-IRS4 & NI-700 IR port are different?
in AMX Hardware
Hi~
I am try to use IR control the B&O BeoSound 3200,
I send the same IRL file to NI-700 and AXB-IRS4,
the NI-700 is working fine,
but AXB-IRS4 is not working.
anyone any ideas?
Thanks~
PS: DIP switch 1~4 are set to the up position
anyone any ideas?
Thanks~
Are you sure the correct IR poet on the box is flashing?
Are you sure the IR emitter is connected correctly and is flashing th code? (Bad IR emitter?)
Are you sure you have addressed the device correctly in your program?
Are you able to manually operate the IR port via diagnostics?
http://www.amx.com//assets/manuals/AXB-IRS4.OperationReferenceGuide.pdf
Make sure these are set correctly.
I know this is not solving your issue but it answers the title of your thread
I will try it again.
I ended up reverting back to the processor IR and taking the gamble with the distance - and it worked.
So I gave up trying to find out what the problem was, I just stopped using the AXB for that code set.
