LG LN5400
Just curious if anyone has had any issues controlling this model via RS-232? We are looking at putting several in a board room for a school district. I know with some flat panels we have run in to issues where when you turn them off you can't turn them back on via RS-232 because of the darn energy smart settings, and I was just looking to make sure no one has run in to problems with this model.
Or if you have a different 47" flat panel you would recommend feel free to throw out suggestions.
Thanks and happy Monday everyone.
Over the last 6 months, at least 8 displays (of 3 different model numbers) were replaced with new models. Given that we found this occurring in all models, we switched over to IR control for this environment because of this device limitation.
With all of that said... there are forum visitors who have field experiences they can share with you as individuals who purchased and integrated third party product.
LG's: It is definitely bad if they are not saving this parameter setting in NV memory.
I'm pretty sure the Sharp TVs save the energy settings when you use their "RSPW" command to enable RS232 power control. I've never had someone need to set it a second time on the same TV. I also add that command into our control module so it always gets sent right before the power off command (just in case).
The Panasonic TVs I've seen don't seem to have the energy saver serial issues.
New NEC pro monitor type displays (like the 4020 and similar) are good, but they have an auto-off that might need disabling.
And the Sony pro monitors with IDTalk Ethernet work fine for power on also.
I was checking out a 60" sharp on Amazon, and best I can tell, even the consumer model Aquos has RS232 -- be sure to check the docs.
Sharp: IP and RS232 on most - be aware that the RW.. command is not a supported command and only works on some models - they all seem to have the magic menu that that you can set it on - this command also effects what IR commands works when off
Panasonic: My preferred brand - always worked if has port (RS232 or IP)
LG: a bit iffy sometimes
I serial them all as it gives me control and feedback for power/source/volume and if its actually connected and listening. Not a fan of stab an IR command and hope the IR bud is connected to something.
