Christie DWU600-G Projector
Having issues parsing the lamp hours from this projector. Re-using a similiar module I created for the LWU505 which worked fine. Seems like they changed thier syntax, which I dont know why. When I use SEND_STRING 0 I get LAMP_HOURS=
MODULE_NAME='Christie DWU600' (DEV dvVP,DEV vdvVP)
(* FILE_LAST_MODIFIED_ON: 09/24/2015 AT: 13:38:54 *)
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
// Video Projector Channels
POWER = 9 // Momentary: Cycle lamp power
DIGIT_0 = 10 // Momentary: Press menu button digit 0
DIGIT_1 = 11 // Momentary: Press menu button digit 1
DIGIT_2 = 12 // Momentary: Press menu button digit 2
DIGIT_3 = 13 // Momentary: Press menu button digit 3
DIGIT_4 = 14 // Momentary: Press menu button digit 4
DIGIT_5 = 15 // Momentary: Press menu button digit 5
DIGIT_6 = 16 // Momentary: Press menu button digit 6
DIGIT_7 = 17 // Momentary: Press menu button digit 7
DIGIT_8 = 18 // Momentary: Press menu button digit 8
DIGIT_9 = 19 // Momentary: Press menu button digit 9
MENU_PLUS_10 = 20 // Momentary: Press menu button plus_10
MENU_ENTER = 21 // Momentary: Press menu button enter
VOL_UP = 24 // Ramping: Ramp volume up
VOL_UP_FB = 24 // Feedback: Volume ramp up feedback
VOL_DN = 25 // Ramping: Ramp volume down
VOL_DN_FB = 25 // Feedback: Volume ramp down feedback
VOL_MUTE = 26 // Momentary: Cycle volume mute
PWR_ON = 27 // Momentary: Set lamp power on
PWR_OFF = 28 // Momentary: Set lamp power off
SOURCE_TV1 = 30 // Momentary: *deprecated Input Source in favor of Input Select* TV 1 source select
SOURCE_VIDEO1 = 31 // Momentary: *deprecated Input Source in favor of Input Select* Video 1 source select
SOURCE_VIDEO2 = 32 // Momentary: *deprecated Input Source in favor of Input Select* Video 2 source select
SOURCE_VIDEO3 = 33 // Momentary: *deprecated Input Source in favor of Input Select* Video 3 source select
SOURCE_TAPE1 = 34 // Momentary: *deprecated Input Source in favor of Input Select* Tape 1 source select
SOURCE_TAPE2 = 35 // Momentary: *deprecated Input Source in favor of Input Select* Tape 2 source select
SOURCE_CD1 = 36 // Momentary: *deprecated Input Source in favor of Input Select* CD 1 source select
SOURCE_TUNER1 = 37 // Momentary: *deprecated Input Source in favor of Input Select* Tuner 1 source select
SOURCE_PHONO1 = 38 // Momentary: *deprecated Input Source in favor of Input Select* Phono 1 source select
SOURCE_AUX1 = 39 // Momentary: *deprecated Input Source in favor of Input Select* Auxiliary 1 source select
MENU_CANCEL = 43 // Momentary: Press menu button cancel
MENU_FUNC = 44 // Momentary: Press menu button menu
MENU_UP = 45 // Momentary: Press menu up button
MENU_DN = 46 // Momentary: Press menu down button
MENU_LT = 47 // Momentary: Press menu left button
MENU_RT = 48 // Momentary: Press menu right button
MENU_SELECT = 49 // Momentary: Press menu Select button (select current item under cursor)
MENU_EXIT = 50 // Momentary: Press menu button exit
MENU_UP_LT = 51 // Momentary: Press menu up left button
MENU_UP_RT = 52 // Momentary: Press menu up right button
MENU_DN_LT = 53 // Momentary: Press menu down left button
MENU_DN_RT = 54 // Momentary: Press menu down right button
MENU_VIDEO = 57 // Momentary: Press menu button video
MENU_THUMBS_DN = 58 // Momentary: Press menu button thumbs down
MENU_THUMBS_UP = 59 // Momentary: Press menu button thumbs up
MENU_ACCEPT = 60 // Momentary: Press menu button accept
MENU_REJECT = 61 // Momentary: Press menu button reject
MENU_LIVE_TV = 62 // Momentary: Press menu button live TV
MENU_SLEEP = 63 // Momentary: Press menu button sleep
MENU_PPV = 64 // Momentary: Press menu button PPV
MENU_FUNCTION = 65 // Momentary: Press menu button function
MENU_SETUP = 66 // Momentary: Press menu button setup
MENU_XM = 77 // Momentary: Press menu button xm
MENU_FM = 78 // Momentary: Press menu button fm
MENU_AM = 79 // Momentary: Press menu button am
MENU_CLEAR = 80 // Momentary: Press menu button clear
MENU_BACK = 81 // Momentary: Press menu button back
MENU_FORWARD = 82 // Momentary: Press menu button forward
MENU_ADVANCE = 83 // Momentary: Press menu button advance
MENU_DIMMER = 84 // Momentary: Press menu button dimmer
MENU_HOLD = 85 // Momentary: Press menu button hold
MENU_LIST = 86 // Momentary: Press menu button list
MENU_LT_PAREN = 87 // Momentary: Press menu button left paren
MENU_RT_PAREN = 88 // Momentary: Press menu button right paren
MENU_UNDERSCORE = 89 // Momentary: Press menu button underscore
MENU_DASH = 90 // Momentary: Press menu button dash
MENU_ASTERISK = 91 // Momentary: Press menu button asterisk
MENU_DOT = 92 // Momentary: Press menu button dot
MENU_POUND = 93 // Momentary: Press menu button pound
MENU_COMMA = 94 // Momentary: Press menu button comma
MENU_DIAL = 95 // Momentary: Press menu button dial
MENU_CONFERENCE = 96 // Momentary: Press menu button conference
MENU_PLUS_100 = 97 // Momentary: Press menu button plus_100
MENU_PLUS_1000 = 98 // Momentary: Press menu button plus_1000
MENU_DISPLAY = 99 // Momentary: Press menu button display
MENU_SUBTITLE = 100 // Momentary: Press menu button subtitle
MENU_INFO = 101 // Momentary: Press menu button info
MENU_FAVORITES = 102 // Momentary: Press menu button favorites
MENU_CONTINUE = 103 // Momentary: Press menu button continue
MENU_RETURN = 104 // Momentary: Press menu button return
MENU_GUIDE = 105 // Momentary: Press menu button guide
MENU_PAGE_UP = 106 // Momentary: Press menu button page up
MENU_PAGE_DN = 107 // Momentary: Press menu button page down
MENU_DECK_A_B = 108 // Momentary: Press menu button deck AB
MENU_TV_VCR = 109 // Momentary: Press menu button TV VCR
MENU_RECORD_SPEED = 110 // Momentary: Press menu button record speed
MENU_PROGRAM = 111 // Momentary: Press menu button program
MENU_AB_REPEAT = 112 // Momentary: Press menu button AB repeat
MENU_HELP = 113 // Momentary: Press menu button help
MENU_TITLE = 114 // Momentary: Press menu button title
MENU_TOP_MENU = 115 // Momentary: Press menu button top menu
MENU_ZOOM = 116 // Momentary: Press menu button zoom
MENU_ANGLE = 117 // Momentary: Press menu button angle
MENU_AUDIO = 118 // Momentary: Press menu button audio
MENU_PREVIEW_INPUT = 129 // Momentary: Press menu button preview input
MENU_SEND_INPUT = 130 // Momentary: Press menu button send input
MENU_SEND_GRAPHICS = 131 // Momentary: Press menu button send graphics
VOL_PRESET = 138 // Momentary: Cycle volume preset
ASPECT_RATIO = 142 // Momentary: Cycle aspect ratio
BRIGHT_UP = 148 // Momentary: Increment brightness
BRIGHT_DN = 149 // Momentary: Decrement brightness
COLOR_UP = 150 // Momentary: Increment color
COLOR_DN = 151 // Momentary: Decrement color
CONTRAST_UP = 152 // Momentary: Increment contrast
CONTRAST_DN = 153 // Momentary: Decrement contrast
SHARP_UP = 154 // Momentary: Increment sharpness
SHARP_DN = 155 // Momentary: Decrement sharpness
TINT_UP = 156 // Momentary: Increment tint
TINT_DN = 157 // Momentary: Decrement tint
PIP_POS = 191 // Momentary: Cycle pip position
PIP_SWAP = 193 // Momentary: Swap pip
PIP = 194 // Momentary: Cycle pip
PIP_ON = 195 // Discrete: Set pip on
PIP_FB = 195 // Feedback: Pip feedback
SOURCE_CYCLE = 196 // Momentary: *deprecated Input Source in favor of Input Select* Cycle source select
VOL_MUTE_ON = 199 // Discrete: Set volume mute
VOL_MUTE_FB = 199 // Feedback: Volume mute feedback
MENU_FLASH = 203 // Momentary: Press menu button flash
PIC_MUTE = 210 // Momentary: Cycle picture/video mute
PIC_MUTE_ON = 211 // Discrete: Set picture/video mute on
PIC_MUTE_FB = 211 // Feedback: Picture/video mute feedback
PIC_FREEZE = 213 // Momentary: Cycle freeze
PIC_FREEZE_ON = 214 // Discrete: Set freeze on
PIC_FREEZE_FB = 214 // Feedback: Freeze feedback
MENU_RESET = 215 // Momentary: Press menu button reset
MENU_INSTANT_REPLAY = 218 // Momentary: Press menu button instant replay
DEVICE_COMMUNICATING = 251 // Feedback: Device online event
DATA_INITIALIZED = 252 // Feedback: Data initialized event
LAMP_WARMING_FB = 253 // Feedback: Lamp is warming up
LAMP_COOLING_FB = 254 // Feedback: Lamp is cooling down
POWER_ON = 255 // Discrete: Set lamp power state
LAMP_POWER_FB = 255 // Feedback: Lamp power state feedback
(** USER DEFINED CONSTANTS**)
ASPECT_RATIO_16X9 = 350
ASPECT_RATIO_4X3 = 351
VP_ZOOM_IN = 352
VP_ZOOM_OUT = 353
SOURCE_VID4 = 357
LAMP_FOCUS_IN = 354
LAMP_FOCUS_OUT = 355
PC_AUTO_ADJUST = 356
SIDE_BY_SIDE = 357
(* VARIABLE DEFINITIONS GO BELOW *)
DEFINE_VARIABLE
NON_VOLATILE CHAR cMsg[25]
(* STARTUP CODE GOES BELOW *)
DEFINE_START
CREATE_BUFFER dvVP, cMsg
(* STRUCTURE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* THE EVENTS GO BELOW *)
DEFINE_EVENT
DATA_EVENT[dvVP]
ONLINE:
SEND_COMMAND dvVP, "'SET BAUD 19200,N,8,1'" //Sets baud rate
SEND_COMMAND dvVP, "'RXON'" //starts serial port
SEND_COMMAND dvVP, "'HSOFF'" //turns handshaking off
ON[vdvVP,DEVICE_COMMUNICATING]
STRING:
SEND_STRING 0, "'FROM PROJECTOR: ',cMsg" //Send VP Msg to TELNET
SELECT
ACTIVE(cMsg = "'(PWR!1)'"): //LAMP is ON
OFF[vdvVP,LAMP_WARMING_FB]
OFF[vdvVP,LAMP_COOLING_FB]
ON[vdvVP,LAMP_POWER_FB]
ACTIVE(cMsg = "'(PWR!0)'"): //LAMP is OFF
OFF[vdvVP,LAMP_POWER_FB]
ACTIVE(cMsg = "'(PWR!11)'"): //LAMP is WARMING
ON[vdvVP,LAMP_WARMING_FB]
ACTIVE(cMsg = "'(PWR!10)'"): //LAMP is COOLING
ON[vdvVP,LAMP_COOLING_FB]
OFFLINE:
OFF[vdvVP,DEVICE_COMMUNICATING]
(**VP Command SET**)
CHANNEL_EVENT[vdvVP,PWR_ON]
CHANNEL_EVENT[vdvVP,PWR_OFF]
CHANNEL_EVENT[vdvVP,SOURCE_VIDEO1] //Input 1 HDMI
CHANNEL_EVENT[vdvVP,SOURCE_VIDEO2] //Input 1 Display Port
CHANNEL_EVENT[vdvVP,MENU_ENTER]
CHANNEL_EVENT[vdvVP,MENU_EXIT]
CHANNEL_EVENT[vdvVP,ASPECT_RATIO_16X9]
CHANNEL_EVENT[vdvVP,MENU_UP]
CHANNEL_EVENT[vdvVP,MENU_LT]
CHANNEL_EVENT[vdvVP,MENU_RT]
CHANNEL_EVENT[vdvVP,MENU_DN]
CHANNEL_EVENT[vdvVP,MENU_SELECT]
ON:
SWITCH(CHANNEL.CHANNEL)
CASE PWR_ON: SEND_STRING dvVP, "'(PWR1)',13"
CASE PWR_OFF: SEND_STRING dvVP, "'(PWR0)',13"
CASE SOURCE_VIDEO1: SEND_STRING dvVP, "'(SIN4) HDMI',13"
CASE SOURCE_VIDEO2: SEND_STRING dvVP, "'(SIN5) DVI-D',13"
CASE MENU_ENTER: SEND_STRING dvVP, "'(KEY17)',13"
CASE MENU_EXIT: SEND_STRING dvVP, "'(KEY17)',13"
CASE ASPECT_RATIO_16X9: SEND_STRING dvVP, "'(KEY67)',13"
CASE MENU_UP: SEND_STRING dvVP, "'(KEY38)',13"
CASE MENU_LT: SEND_STRING dvVP, "'(KEY39)',13"
CASE MENU_RT: SEND_STRING dvVP, "'(KEY41)',13"
CASE MENU_DN: SEND_STRING dvVP, "'(KEY42)',13"
CASE MENU_SELECT: SEND_STRING dvVP, "'(KEY40)',13"
CHANNEL_EVENT[vdvVP, SIDE_BY_SIDE]
ON:
SEND_STRING dvVP, "'(PIP 1)',13"
OFF:
SEND_STRING dvVP, "'(PIP 0)',13"
CHANNEL_EVENT[vdvVP,LAMP_FOCUS_IN]
ON:
SEND_STRING dvVP, "'(KEY5)',13"
OFF:
CHANNEL_EVENT[vdvVP,LAMP_FOCUS_OUT]
ON:
SEND_STRING dvVP, "'(KEY6)',13"
OFF:
CHANNEL_EVENT[vdvVP,VP_ZOOM_IN]
ON:
SEND_STRING dvVP, "'(KEY9)',13"
OFF:
CHANNEL_EVENT[vdvVP,VP_ZOOM_OUT]
ON:
SEND_STRING dvVP, "'(KEY10)',13"
OFF:
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
WAIT 50
SEND_STRING dvVP, "'(PWR?)',13" (**Every 5 sec Poll Lamp**)
WAIT 22
CLEAR_BUFFER cMsg
SEND_STRING dvVP, "'(LIF+LP1H?)',13" (**Every 2sec Poll Lamp**)
REMOVE_STRING(cMsg, '(LIF+LP1H!', 1)
LEFT_STRING(cMsg, 5)
SEND_STRING vdvVP, "'LAMPTIME=',cMSG"
SEND_STRING 0, "'LAMPTIME=',cMSG"
CLEAR_BUFFER cMsg
