Migrate to Precis DSP 1818 with Alero AMP8
                    hello every one,
I want to replace my MI0808 audio controller (master and expander) by Precis DSP 1818 with 2 Alero AMP8
I have to change the audio module anyone can help me about the prog? an example will be fine
thanx in advance
thanx in advance
and for volume...
sorry, I have not mentioned that the Precis DSP 1818 will be controlled by an NI2100
I'm new in programming and I want to know if the statement I / O is the same as the MI0808 to know that I have 7 inputs and 11 outputs zones (2 speakers in each zone )
thank u again
I'm having trouble understanding the question. If the MIO808 you mention is a keypad - then that is the user interface. (the thing the client uses to control the system) The NI-2100 is the controller/processor where the programming resides. The Precis switcher/dsp will connect to the NI-2100 with a standard serial cable (rs232) into one of the NI's 3 serial ports.
Once you have all that hooked up and tested, you'll need to write the code to enable the user to operate the audio system. If there was some code before that worked with a different system then it may be as simple as modifying the code to work with the new switch. If not, then you'll need to craft some code yourself.
If you're asking one of us to do it for you then you can work out an arrangement with one of the forum members where they can write it for you and you can pay them for their time. All of us on the forum do this for a living. I, for example, am an independent programmer. There are many independents on the forum as well as integration employees who'd be happy to help out.
If you're wanting to learn how to code yourself (I highly recommend you do this - it's a lot of fun) I'd highly recommend contacting your AMX sales rep or your integration firm's boss to send you to the AMX classes on programming. It is time well spent and you'll learn a lot that will get you started.
Cheers!
Eric
