DVX-3255 Ethernet port config
in AMX Hardware
Silly question.
Is there any way to set the ethernet port on the DVX-3255 to manual 100/full instead of auto? I can't seem to find the command or the place on the web configuration to do so.
Thank you
Thank you
...and the telnet command to set the device to 100/full duplex are?
Odd they are not in the manual or the programming guide that I can see for the 3255. And on a general listing with the '?' query, I cannot see a command either.
Has this been eliminated with the NX processor?
I could just be missing it, but I'm not seeing it.
If you're ever stuck for the commands from the telnet/SSH prompt just type `help`
https://en.wikipedia.org/wiki/Duplex_mismatch#Duplex_mismatch_due_to_autonegotiation
