RAKO RAV232 + AMX device duet module + jar file
Hi there.
I'm returning to some amx coding after having a long time away from it. Yesterday I grabbed some old kit to get reacquainted with my old friend.
So, RAV232 plugged in to rs232 port 1 on my NI 3100 (running latest firmware) and subsequently grabbed the "Rako_RAV232_v1_0_0_dr1_0_0.zip" and "Rako_RAV232_Comm_dr1_0_0.jar". back in netlinx studio, a quick check and the default port seems to be correct (5001:1:0) (not at home at the moment so can't check) and i'm using an emulated touch panel until a budget Android tablet arrives in the post... anyway, compile + quick upload and a reboot ...
In panelbuilder, I connect to the NI3100 and run the preview panel - which as supplied from amx should allow me to query the rav232 firmware + some basic lighting adjustments. It appears as though the rako module is offline.
It has been a while since I have done any coding, so any help with getting this default module up and running would be *very* much appreciated! I still have my paperwork from Programmer 1, which i'll be digging out of the loft over the weekend.
Kind regards
Kind regards
After some double-checking device details + other details were all in good order, I also took the liberty of updating the RAKO device firmware. Some time later, I can now control the RAKO box.
Next, I'll try and bring this sample code into my own project and retain control.
One question if I may. Here's a portion of code that I'm unsure about:
(************************************************* **********) (* CONSTANT DEFINITIONS GO BELOW *) (************************************************* **********) DEFINE_CONSTANT // User must fill in these values VOLATILE CHAR dLightAddress[16][8] = { '10', //Example light addresses '11', //Change the addresses to match your system. '12', //the 0 element adjust all channels in a room. '13', '14', '15', '16', '17', '18', '19', '110', '111', '112', '113', '114', '115' } VOLATILE CHAR sLightAddress[4][8] = { '1:S1', //Example scene addresses '1:S2', //Change the addresses to match your system. '1:S3', '1:S4' }It's pretty clear that "user must fill in these values" ... but I am unsure as to what I need to put where. Many thanks in advance.
