EWS Shceduling plugin v4.1.15
                    Hi there,
When going into the resource profiles via the scheduling configuration on the RMS server i have, one of my resources don't select the checkbox when i want to use in RMS. Obviously this is prevetnting me from mapping it to a location.
Bearing in mind, this particular room mailbox is also giving me grief when using the ExchangeAPI diagnositc tool. I had a similair issue with another and the solution was to delete all meetings older than a year. Tried this but it didn't have any positive results.
Looked at the DEBUG Logs via the Log4net and also what the legacy troller is pulling about the room. where SyncState is there should be a whloe bunch of data in there but not for this room.
In dire need of help !
Thank you.
Thank you.
Thanks Matt,
Will try this.
Thats now solved.
i have moved onto the latest Exchange interface that was released in May, now have an issue when selecting the resource profile to use in RMS. when i save (once the profile has tick) the profile does stay ticked?
