EXB-REL8
Hi everyone.
I'm a newbie and I have to configure two ICSLAN modules.
I tried to connect them on a NX 4200 ICSlan ports and I tried to re-configure the netports as shown in the manual, but the ip address class won't change once the parameters are saved (don't know why).
I launch from telnet set ICSLAN and complete all the infos the system asks, but once rebooted, it switches to a 0.0.0.0 network address which brings to nothing...
So i decided to patch them directly to the ethernet and assigned static ip's to both and I try from the netlinx studio to control the device: I can send the LED-EN and LED-DIS command, but I can't switch ON or OFF the channels!!
All the fisical cabling are done and I tested all the relays, which work correctly, but I can't use the EXB channels from Code.
Anyone can give me a hint on how to "code" that?
Only when it appears in the device tree of the NX master will the EXB be controllable in code.
The code was well written and I configured correctly the device, but the NX-4200 was broken and didn't responds to any command!
Thanks again guys
