Simple concept, brick wall implementation.
Been working on this for a few days, and have had no results. On a CV12, I have 4 rows of camera presets for a VC system. I would like users to press a button used to label to row of presets, enter a name, and have that name populate the button. I understand all the tools to do what I want, text entry, variable text to buttons, etc, but cannot get them to all work together that way I want. If there is a way to do this in the panel, and not include controller programing, that would be ideal, but making it work is the priority.
Pull up the keyboard on the TP
Populate the variable that already exists
Have the user enter a new name from that keyboard
Save that to a variable and/or text file
Update the name on the TP.
Do each step one at a time and Im sure you can knock it out of the park.
Meh, you don't need it. It's pretty straight-forward level 1 or 2 programming. just grab the TP programming manual off the AMX tech site and you'll be just fine. Every command you'll need is easily sent to the panel via Control A Device. As suggested, you can just manually send the commands, test, then write your code. Easy Peasy.
