Upload Source Code
All of a sudden I can upload SRC files but cannot open in studio. If I open the file in note pad I just get a bunch of symbols, and some random text. Suggestion box wide open. Thanks.
    bano wrote: »
    I don't have enough info in the post to be sure - but a guess is that you've tried to download some code from a master and then want to look at it. You might use the Tools>File Extraction>Extract From Src. It will prompt you to navigate to where you want to save the file and hit enter. then try opening the resultant file from that.
  • Or rename it to whatever . zip
  • banobano Posts: 175
    @ericmedley said:
    (Quote)
    That did the trick! I hadn't done it in so long I forgot. Thank you sir!
  • richardhermanrichardherman Posts: 407
    edited August 2020
    Wow, that's some serious extraction time: september 2017 > august 2020 :p
