Check out the Oppo BDP-83. Not yet released, but has optional RS232.
I have done a lot of work with the Oppo DVD players and the protocol works pretty well.
Can't wait till this gets released.. they think by August it should be in full release.
If you take analogue PCM output from the 3800 be careful. There is a -10DB trim on the Sub output. An appropriate Denon processor will put it back on but if you're taken it to a Lexicon, ADA or something similar then you'll have to stick that gain back in via a line driver or equivalent
While it's a reasonable player we're not going to use one again until that particular feature is addressed.
I now have the RS232 documents for the Sony, Pioneer, Yamha and Denon, a quick comparison:
Sony:
Commands: Only basic
Feeback: Nothing Useful (Only Model and Firmware version)
Denon/Marantz:
Commands: Complete - More than remote
Feedback: Track, Time and Media. Excellent status with full audio format, subtitle and angle reporting.
Yamaha:
Commands: Complete
Feedback: Track, Time, Status and Media.
Pioneer:
Commands: Complete
Feedback: Track, Time and Basic Status
You can add Marantz to the list, though it is really a Denon with Marantz's name on it. It uses the same protocol as the Denon as well. I've used the BD-8002, specifically.
I would guess so since they have the same parent company. I have used the Denon in the past, but just with code that I had written on my own. The codes work very well that I have written, but I normally do not use heavy polling in order to optimize performance in the system.
I have not tried to use any of the modules from AMX because IMO they typically are really bloated, slow and kill the performance of a system any time they are included. What have other found that have tried to use the AMX module for the Denon?
Denon, Marantz, McIntosh, Escient, Snell, and Boston Acoustics are all owned by D&M Holdings.
Just put in an RS232 enabled Oppo BDP-83R, works nicely and I will likely use them in future.
I love the Oppo BDP-83 player as well, you can download a module from http://modulemarketplace.com/index.php?l=product_detail&p=32
This player is one of the only BluRay players that will also play SACDs and DVD Audio discs as well. Also load and power on time is lighting fast compared to other BluRay players.
Dan
mahalo,
Look at this:
http://www.vidabox.com/Products/MAX/MAX_Specs.htm
http://www.vidabox.com/Products/LUX/LUX_Specs.htm
The only ones with reasonable 2 way I know of are the two Denons:
DVD-2500BT
DVD-3800BD
The Sony 5000ES seems to only really offer basic 1 way commands although you can query the Software version.......
There is also a Yamaha and a few Pioneers, anyone have any experience of these?
Sony:
Denon/Marantz:
Yamaha:
Commands: Complete
Pioneer:
Commands: Complete
I'm guessing these are either very closely related or identical to the three upcoming Denons?
