Volume Run-Away
in AMX Hardware
Hi
Another problem,
I have a customer whose system has lost control about 3-4 time now,
He reports that when turning the volume up from the MVP-8400 with one button push the volume runs away until max, nearly blowing his speakers!
Could this be a wireless issue, the amps are controlled by IR, so i assume that it must be a programming error.
This does not happen often but i would like to resolve it as it is off putting when you lose control oif something like volume,
Any advice would be great
Ross Wylie
Another problem,
Ross Wylie
Without seeing your code, it might be difficult for anyone here to help you.
But, given that you're controlling your amp with IR, you should check to make sure you're PULSEing the channel and not turning it ON. If you are, check your pulse time. Look at the front of your master to make sure the volume up code isn't being sent longer than you intend.
If it's #2, your only choice is improve the signal to the touch panel. You might be able to cut back incidents of it by changing from a PUSH/RELEASE method or a TO method, and use the HOLD[xx], REPEAT handler instead. It still is going to need to see a release, but might keep the buildup on hte equipment end from getting too large by limiting how much goes out in a short time. Ask your customer if tapping the voume button a few times will stop it. If it ramps so quickly they don't have time, you may want to consider the REPEAT handler anyway, just to pace the volume ramping.
There was a small bug with the 7500 panel - possibly same as 8400 and AMX have released a firmware revision that fixed it - it didn't throw a release from the panel. I simply did a time out as a work around of say 3 seconds to ensure that this never happened again - my client was a Crematorium and the service - Hells Angels bikie - bugger back into hiding for me.
No matter how reliable the hardware or the software it is vital to prevent volume ramping endlessly. What if the user left a book leaning on the touchpanel? So build in a timeout.
BUTTON_EVENT[vdvMVP1,143]
BUTTON_EVENT[vdvMVP2,143]
PUSH:
MVP = BUTTON.INPUT.DEVICE.NUMBER-33130
SEND_STRING dvDEBUG,"'Volume Muted in - ',ITOA(ROOM_SELECT[MVP])"
SELECT
ACTIVE(ROOM_SELECT[MVP] = KITCHEN_SEL) : TO[dvAMP_KITCHEN,26]
ACTIVE(ROOM_SELECT[MVP] = BATHROOM_SEL) : TO[dvAMP_BathRoom,26]
ACTIVE(ROOM_SELECT[MVP] = LIVING_SEL) : TO[dvAMP_Living,26]
ACTIVE(ROOM_SELECT[MVP] = LOUNGE_SEL) : TO[dvAMP_LOUNGE,26]
ACTIVE(ROOM_SELECT[MVP] = GARDEN_SEL) : TO[dvAMP_GARDEN,26]
ACTIVE(ROOM_SELECT[MVP] = BEDROOM_SEL) : TO[dvAMP_BedRoom,26]
