Hunter Douglas blinds?
                    Hey guys,
Anyone hooked up Hunter Douglas motorized blinds to AMX? Looking for a cheaper type solution for motorized blinds.
Dan
Dan
Thanks Jeremiah - which ones did you use?
We have controlled both the IR and switched blinds. The switched units use a DC motor (2 wire) and you just reverse the current for UP or DOWN. There is a limit switch built into the blind at each end that is adjustable. We build a little 3-relay circuit to control the blinds. I don't like the IR controlled blinds. I can send you a circuit diagram for the reversing relays if you would like.
